Software para Ajustes e Reset das Almofadas das Impressoras e Multifuncionais Canon
Programa destinado para uso técnico, para fazer ajustes e reset das almofadas, quando a impressora aparecer no status mensagens de SERVIÇO REQUERIDO, ALMOFADAS DE TINTA CHEIA ou PEÇAS ESTÃO NO FIM DA VIDA ÚTIL, como por exemplo Códigos de Erros 1700, 1702, 1703, 1704, 1705, 1712, 1713, 1714, 1715, 6700, 5B00, 5B01, 5B02, 5B03, 5B04, 5B05, 5B12, 5B13, 5B14 ou 5B15.
Modelos Compatíveis:
E-series: E200, E300, E3100, E460, E461, E464, E468, E480, E481, E484, E488 e E489.
G-series: G1000, G1010 G1100, G1110 G1200, G1210, G1400, G1410, G1500, G1510, G1800, G1810, G2000, G2010, G2100, G2110, G2200, G2210, G2400, G2410, G2500, G2510, G2600, G2610, G2800, G2810, G2900, G2910, G3000, G3010, G3100, G3102, G3111, G3200, G3210, G3400, G3410, G3500, G3510, G3600, G3610, G3800, G3810, G3900, G3910, G4000, G4010, G4100, G4110, G4111, G4200, G4210, G4400,G4410, G4500, G4510, G4600, G4610, G4800, G4810, G4900, G4910, G4902, G4912, G6010, G7010. (Não é MG, somente G).
IB-series: IB4000, IB4010, IB4020,IB4040, IB4050, IB4060,IB4070, IB4080,IB4090, IB4100, IB4110, IB4120,IB4140, IB4150, IB4160,IB4170, IB4180 e IB4190.
IP-series: IP7240, IP110, IP8710, IP8740, IP2870S e IP2880S.
IX-series: IX6810 e IX6840.
MB-series: MB2000, MB2010, MB2020, MB2040, MB2050, MB2060, MB2100, MB2110, MB2120, MB2140, MB2150, MB2160, MB2300, MB2320, MB2340, MB2350, MB2360, MB2390, MB2700, MB2710, MB2720, MB2740, MB2750, MB2760, MB2790, MB5000, MB5010, MB5020, MB5040, MB5050, MB5060, MB5070, MB5080, MB5090, MB5100, MB5110, MB5120, MB5140, MB5150, MB5160, MB5170, MB5180, MB5190, MB5400, MB5410, MB5420, MB5440, MB5450, MB5460, MB5470, MB5480 e MB5490.
MG-series: MG2570S, MG2580S, MG3600, MG3610, MG3620, MG3640, MG3650, MG3660, MG3670, MG3680, MG5200, MG5210, MG5500, MG5510, MG5520, MG5540, MG5550, MG5560, MG5570, MG5580, MG5600, MG5610, MG5620, MG5640, MG5650, MG5660, MG5670, MG5680, MG5700, MG5710, MG5720, MG5721, MG5722, MG5740, MG5750, MG5751, MG5752, MG5753, MG5760, MG5765, MG5766, MG5770, MG5780, MG5790, MG5795, MG6700, MG6800, MG6820, MG6821, MG6822, MG6840, MG6850, MG6851, MG6852, MG6853, MG6860, MG6865, MG6866, MG6870, MG6880, MG6890, MG6930, MG7700, MG7710, MG7720, MG7740, MG7750, MG7751, MG7752, MG7753, MG7760, MG7765, MG7766, MG7770, MG7780 e MG7790.
MX-series: MX320, MX328, MX330, MX338, MX340, MX347, MX348, MX350, MX357, MX358, MX360, MX370, MX390, MX450, MX470, MX471, MX472, MX474, MX475, MX476, MX477, MX478, MX490, MX491, MX492, MX494, MX495, MX496, MX497, MX498, MX499, MX520, MX530, MX531, MX532, MX534, MX535, MX536, MX537, MX538, MX710, MX720, MX890, MX920 e MX924.
TR-series:
TS-series: TS200, TS300, TS3100, TS3110, TS3120, TS3122, TS3129, TS3140, TS3150, TS3151, TS3160, TS3165, TS3166, TS3170, TS3170S, TS3177S, TS3180, TS3190, TS3195, TS5000, TS5010, TS5020, TS5040, TS5050, TS5051, TS5053, TS5060, TS5070, TS5080, TS5090, TS5100, TS5110, TS5120, TS5140, TS5150, TS5151, TS5160, TS5170, TS5180, TS6000, TS6010, TS6020, TS6040, TS6050, TS6051, TS6052, TS6060, TS6070, TS6080, TS6100, TS6110, TS6120, TS6140, TS6150, TS6151, TS6160, TS7500, TS8000, TS8010, TS8020, TS8040, TS8050, TS8051, TS8052, TS8053, TS8060, TS8070, TS8080, TS8090, TS8100, TS8120, TS8140, TS8150, TS8151, TS8152, TS8160, TS8170, TS8190, TS8195, TS8500, TS9000, TS9010, TS9020, TS9040, TS9050, TS9055, TS9060, TS9080, TS9100, TS9120, TS9140, TS9150, TS9155, TS9160 e TS9170.
XK-series: XK50 e XK70.
IMPORTANTE, MODELOS QUE NÃO ACEITAM RESET POR SOFTWARE, PRECISA REGRAVAR O EEPROM:
E400, E404, E407, E408, E410, E414, E417, E418, E470, E471, E477, E478, MG2400, MG2410, MG2450, MG2500, MG2510, MG2550, MG2910, MG3010, MG3020, MG3022, MG3040, MG3050, MG3051, MG3052, MG3053, MG3060, MG3070, MG3077, MG3070S, MG3077S, MG3080 e MG3090 não são compatíveis com o procedimento de reset, elas não aceitam o reset, pois são modelos "descartáveis" segundo o fabricante, nesse caso pode-se tentar a regravação da Eprom, ou seja, o software não funciona não nesses modelos.
11. Na aba "Main" do software, localize a parte "Ink Absorber Counter", selecione "Main / ou Main_Black / ou Main_Color", depende do modelo e clique em "SET".
15. Veja os vídeos abaixo que explica o passo-a-passo, se não conseguir fazer os procedimentos entre em contato conosco solicitando Suporte Técnico que fazemos acesso remoto para verificar.
