Software Reset para Canon E, G, IB, IP, IX, MB, MG, MX, TR, TS e XK (Atenção: Veja os Modelos Compatíveis) 5.610
R$49,90
   (10 análises)
10 Screenshots
Software para Ajustes e Reset das Almofadas das Impressoras e Multifuncionais Canon
Modelos Compatíveis:
E-series: E200, E300, E3100, E460, E461, E464, E468, E480, E481, E484, E488 e E489.
G-series: G1000, G1010 G1100, G1110 G1200, G1210, G1400, G1410, G1500, G1510, G1800, G1810, G2000, G2010, G2100, G2110, G2200, G2210, G2400, G2410, G2500, G2510, G2600, G2610, G2800, G2810, G2900, G2910, G3000, G3010, G3100, G3102, G3111, G3200, G3210, G3400, G3410, G3500, G3510, G3600, G3610, G3800, G3810, G3900, G3910, G4000, G4010, G4100, G4110, G4111, G4200, G4210, G4400,G4410, G4500, G4510, G4600, G4610, G4800, G4810, G4900, G4910, G4902, G4912, G6010, G7010. (Não é MG, somente G).
IB-series: IB4000, IB4010, IB4020,IB4040, IB4050, IB4060,IB4070, IB4080,IB4090, IB4100, IB4110, IB4120,IB4140, IB4150, IB4160,IB4170, IB4180 e IB4190.
IP-series: IP7240, IP110, IP8710, IP8740, IP2870S e IP2880S.
IX-series: IX6810 e IX6840.
MB-series: MB2000, MB2010, MB2020, MB2040, MB2050, MB2060, MB2100, MB2110, MB2120, MB2140, MB2150, MB2160, MB2300, MB2320, MB2340, MB2350, MB2360, MB2390, MB2700, MB2710, MB2720, MB2740, MB2750, MB2760, MB2790, MB5000, MB5010, MB5020, MB5040, MB5050, MB5060, MB5070, MB5080, MB5090, MB5100, MB5110, MB5120, MB5140, MB5150, MB5160, MB5170, MB5180, MB5190, MB5400, MB5410, MB5420, MB5440, MB5450, MB5460, MB5470, MB5480 e MB5490.
MG-series: MG2570S, MG2580S, MG3600, MG3610, MG3620, MG3640, MG3650, MG3660, MG3670, MG3680, MG5200, MG5210, MG5500, MG5510, MG5520, MG5540, MG5550, MG5560, MG5570, MG5580, MG5600, MG5610, MG5620, MG5640, MG5650, MG5660, MG5670, MG5680, MG5700, MG5710, MG5720, MG5721, MG5722, MG5740, MG5750, MG5751, MG5752, MG5753, MG5760, MG5765, MG5766, MG5770, MG5780, MG5790, MG5795, MG6700, MG6800, MG6820, MG6821, MG6822, MG6840, MG6850, MG6851, MG6852, MG6853, MG6860, MG6865, MG6866, MG6870, MG6880, MG6890, MG6930, MG7700, MG7710, MG7720, MG7740, MG7750, MG7751, MG7752, MG7753, MG7760, MG7765, MG7766, MG7770, MG7780 e MG7790.
MX-series: MX320, MX328, MX330, MX338, MX340, MX347, MX348, MX350, MX357, MX358, MX360, MX370, MX390, MX450, MX470, MX471, MX472, MX474, MX475, MX476, MX477, MX478, MX490, MX491, MX492, MX494, MX495, MX496, MX497, MX498, MX499, MX520, MX530, MX531, MX532, MX534, MX535, MX536, MX537, MX538, MX710, MX720, MX890, MX920 e MX924.
TR-series:
TS-series: TS200, TS300, TS3100, TS3110, TS3120, TS3122, TS3129, TS3140, TS3150, TS3151, TS3160, TS3165, TS3166, TS3170, TS3170S, TS3177S, TS3180, TS3190, TS3195, TS5000, TS5010, TS5020, TS5040, TS5050, TS5051, TS5053, TS5060, TS5070, TS5080, TS5090, TS5100, TS5110, TS5120, TS5140, TS5150, TS5151, TS5160, TS5170, TS5180, TS6000, TS6010, TS6020, TS6040, TS6050, TS6051, TS6052, TS6060, TS6070, TS6080, TS6100, TS6110, TS6120, TS6140, TS6150, TS6151, TS6160, TS7500, TS8000, TS8010, TS8020, TS8040, TS8050, TS8051, TS8052, TS8053, TS8060, TS8070, TS8080, TS8090, TS8100, TS8120, TS8140, TS8150, TS8151, TS8152, TS8160, TS8170, TS8190, TS8195, TS8500, TS9000, TS9010, TS9020, TS9040, TS9050, TS9055, TS9060, TS9080, TS9100, TS9120, TS9140, TS9150, TS9155, TS9160 e TS9170.
XK-series: XK50 e XK70.
IMPORTANTE, MODELOS QUE NÃO ACEITAM RESET POR SOFTWARE, PRECISA REGRAVAR O EEPROM:
E400, E404, E407, E408, E410, E414, E417, E418, E470, E471, E477, E478, MG2400, MG2410, MG2450, MG2500, MG2510, MG2550, MG2910, MG3010, MG3020, MG3022, MG3040, MG3050, MG3051, MG3052, MG3053, MG3060, MG3070, MG3077, MG3070S, MG3077S, MG3080 e MG3090 não são compatíveis com o procedimento de reset, elas não aceitam o reset, pois são modelos "descartáveis" segundo o fabricante, nesse caso pode-se tentar a regravação da Eprom, ou seja, o software não funciona não nesses modelos.
8. Solte o botão Cancelar e Aperte 5X o botão Cancelar. (o botão liga/desliga ainda continua pressionado).
11. Na aba "Main" do software, localize a parte "Ink Absorber Counter", selecione "Main / ou Main_Black / ou Main_Color", depende do modelo e clique em "SET".
15. Veja os vídeos abaixo que explica o passo-a-passo, se não conseguir fazer os procedimentos entre em contato conosco solicitando Suporte Técnico que fazemos acesso remoto para verificar.
  • Curtir 1
  • Obrigado 4
Emmanuelly Felizardo
   3 de 3 membros acharam esta análise útil 3 / 3 membros
Resolução super rápida e simples de executar. Serviço nota 1000, parabéns!!! 🤝
Link para a análise
Buffet Vanzetto
   2 de 2 membros acharam esta análise útil 2 / 2 membros
Obrigada pelo suporte! A impressora do nada parou de funcionar... a Canon me deixou na linha por mais de 10 minutos e não obtive atendimento. Fui procurar na internet como resolver e cheguei até vocês. Como existe a opção de pagar via PIX ou transferência, me senti segura para fazer o pagamento e o atendimento do Ramon via whatsapp, super eficiente!
Link para a análise
Suellen Amarante
Funcionou perfeitamente! Tudo certinho, pra mim que não sei mexer nessas coisas de informática, deu tudo certo. Obrigada pela passo a passo que tem no youtube. 😉
Link para a análise
diegomatte
Muito bom! Confesso que estava desconfiado devido ao fato de ter que pagar para baixar o arquivo.
Paguei, baixei o arquivo, segui o passo-a-passo e a minha impressora voltou a funcionar.
Link para a análise
Bibopai
Solução rápida e certeira, muito bom mesmo. Parabéns à toda a equipe Sulink.
Link para a análise
Luciana L. Santos
· Editado por Luciana L. Santos
   1 de 1 membros acharam esta análise útil 1 / 1 membro
Tive dificuldades no começo por apresentar um erro de vírus ao tentar baixar o software, mas com o auxílio técnico da Sulink consegui baixar e deu super certo. Impressora funcionando perfeitamente!
Link para a análise
Rita Altoé
Funcionou perfeitamente!!! Parabéns pelo serviço tudo muito bem explicado no post.
Link para a análise
cinthia
   1 de 2 membros acharam esta análise útil 1 / 2 membros
muito obrigado eu  estava disisperada.no momento o que esta salvando minha loginha e a inpressao sou do interior e deu super certo
Link para a análise
