Epson M205 - Recovery Firmware - Firmware de Recuperação 1.0.0
Recovery Firmware / Firmware de Recuperação para  Epson M205.
Versão do Firmware: MY19I1
Recovery Firmware for Epson M205.
Firmware version: MY19I1
