  • Thanks 1
Epson XP-240, XP-241, XP-440 e XP-441 - Software de Ajuste e Reset Epson / Printer Adjustment Software and Reset Software (License ID)
$7.90 or VIP Member
Software de Ajuste e Reset das Impressoras Epson XP 240, XP 241, XP 440 e XP 441.
Acesse o Fórum Sulink e abra um ticket de suporte com o assunto "Hardware ID EPSON XP-241, XP-441" e cole o Hardware ID que copiou.
Epson XP240, XP241, XP440 and XP441 Printer Adjustment Software and Reset Software.
Access the Sulink Forum and open a support ticket with the subject "Hardware ID EPSON XP-241, XP-441" and paste the Hardware ID you copied.
