Epson WF-8093, WF-8593 - Software de Ajuste das Impressoras Epson / Printer Adjustment Software 1.0.0
$6.90 or VIP Member
Software de Ajuste das Impressoras Epson WF 8093, WF 8593.
ATENÇÃO: Este software NÃO FAZ RESET do erro de almofada de tinta cheia, pois esses modelos de impressora utilizam "Caixa de Resíduos de Tinta com Chip", ou seja, precisa trocar ou resetar esse chip (ou trocar a caixa completa) para que volte a funcionar.
Esse programa não resolve problemas como: ERRO DE ATOLAMENTO DE PAPEL, ERRO GERAL, ERRO SCANNER, ERRO DE CARTUCHOS INCOMPATÍVEIS OU VAZIOS, ERRO DE ALMOFADAS CHEIAS OU ERRO DE QUE PEÇAS CHEGARAM AO FIM DA VIDA ÚTIL.
Epson WF 8093, WF 8593 Printer Adjustment Software.
CAUTION: This software DOES NOT RESET the full ink cushion error as these printer models use "Chip Ink Waste Box", ie you need to change or reset that chip (or change the entire box) to come back to work.
This program does not solve problems such as: PAPER JAM ERROR, GENERAL ERROR, SCANNER ERROR, ERROR OF INCOMPATIBLE OR EMPTY CARTRIDGES, ERROR OF FULL PADS OR ERROR THAT PARTS ARRIVED AT THE END OF LIFE.
Other Files from ADM
