Epson L495 - Recovery Firmware / Firmware de Recuperação 1.0.0
Recovery Firmware / Firmware de Recuperação para Epson L495.
Versão do Firmware: RX14I9
Recovery Firmware for Epson L495.
Firmware version: RX14I9
