Epson Stylus PRO 7700 - Recovery Firmware / Firmware de Recuperação 1.0.0
Recovery Firmware / Firmware de Recuperação para Epson Stylus PRO 7700.
Versão do Firmware: KND02C8
Recovery Firmware for Epson Stylus PRO 7700.
Firmware version: KND02C8
