Epson WF-2750 - Recovery Firmware - Firmware de Recuperação (Windows) JP02I2
ecovery Firmware / Firmware de Recuperação para  Epson WF-2750.
Versão do Firmware: JP02I2
Recovery Firmware for Epson WF-2750.
Firmware version: JP02I2
