Epson L656 - Recovery Firmware / Firmware de Recuperação 1.0.0
Recovery Firmware / Firmware de Recuperação para Epson L656.
Versão do Firmware: DC30IB
Recovery Firmware for Epson L656.
Firmware version: DC30IB
