Epson ET-2750 - Recovery Firmware - Firmware de Recuperação (Windows) 1.0.0
Recovery Firmware - Firmware de Recuperação para  Epson Epson ET-2750.
Versão do Firmware: LW15I6
Recovery Firmware for  Epson ET-2750.
Firmware version: LW15I6
