Recovery Firmware Mode - Firmware de Recuperação para Epson WF2630.
Versão do Firmware: LF25I7 - Windows.
Data: 19/02/2019
O Recovery Firmware serve para recuperar sua impressora que entrou em modo recovery após tentar realizar um update e travou, ou está em modo recovery.
Recovery Firmware Mode for Epson WF2630.
Firmware version: LF25I7 - Windows.
Data: 19/02/2019
Recovery Firmware is meant to recover your printer that went into recovery mode after trying to perform an update and crashed, or is in recovery mode.
