Epson TX525FW - Recovery Firmware - Firmware de Recuperação (Windows)
Recovery Firmware - Firmware de Recuperação para  Epson Epson TX525FW.
Versão do Firmware: GL11C5
Recovery Firmware for  Epson TX 525 FW.
Firmware version: GL11C5
