Epson WF-2530 - Recovery Firmware / Firmware de Recuperação
MAIS INFORMAÇÕES
Recovery Firmware / Firmware de Recuperação para Epson WF-2530.
Versão do Firmware: LD18FC
>PARA QUE SERVE?
Recovery Firmware forEpson WF-2530.
Firmware version: LD18FC
- Windows operating system.
