Administrator Sulink Posted December 19, 2018 Administrator Share Posted December 19, 2018 Epson XP-340 - Recovery Firmware - Firmware de Recuperação (Windows) MAIS INFORMAÇÕES Recovery Firmware / Firmware de Recuperação para Epson XP-340. Versão do Firmware: MJ08I5 >PARA QUE SERVE? O Recovery Firmware serve para recuperar sua impressora que entrou em modo recovery após tentar realizar um update e travou, ou está em modo recovery. No estado de recovery a impressora liga porem fica travada). Atenção: O firmware recovery não resolve problemas de erro geral, papel preso, almofadas cheias e outros erros, apenas resolve o problema de firmware corrompido quando a impressora se encontra travada em update/recovery mode. REQUISITOS:- Sistema Operacional Windows.- A impressora deve estar corretamente instalada no PC e conectada por cabo USB. English translation Recovery Firmware for Epson XP-340. Firmware version: MJ08I5 > WHAT DOES IT SERVE? Recovery Firmware is meant to recover your printer that went into recovery mode after trying to perform an update and crashed, or is in recovery mode. In the recovery state the printer turns on but is locked). Attention: The firmware recovery does not solve general error problems, paper jam, full pads and other errors, it only solves the problem of corrupted firmware when the printer is locked in update / recovery mode. REQUIREMENTS: - Windows operating system. - The printer must be properly installed in the PC and connected by a USB cable. Autor Sulink Enviado 19-12-2018 Categoria Downgrade Update Recovery Firmware Quote Link to comment Share on other sites More sharing options...
