Epson Stylus PRO 7890 - Recovery Firmware / Firmware de Recuperação
MAIS INFORMAÇÕES
Recovery Firmware / Firmware de Recuperação para Epson Stylus PRO 7890.
Versão do Firmware: JN124G5
>PARA QUE SERVE?
Recovery Firmware for Epson Stylus PRO 7890.
Firmware version: JN124G5
- Windows operating system.
