Bom dia. Tenho uma L4150 e após varias tentativas de limpeza leve e limpeza pesada pelo software da Epson resolvi retirar a cabeça de impressão para desentupi-la. Ao recoloca-la a impressora entrou em modo de erro geral com todas as luzes piscando. Desmontei de novo pra ver se havia queimado o flat devido a algum curto mas vi que está tudo normal aparentemente. Eu injetei água desmineralizada pra desentupir a cabeça e pelo menos funcionou pois ao injetar com a seringa dava pra ver a névoa saindo. Usei o software WicReset e esse foi o log do erro:
Model Name L4150 Series
Status Fatal error
Firmware ver. LX27JB 27/11/2019
MAC-ID String F8:D0:27:4D:08:E9
Serial Number X59D130001
Print Head ID 385886CQ0E
First TI received time 01/03/2019
Manual cleaning counter 0
Timer cleaning counter 0
Ink replacement cleaning counter 0
Total print pass counter 210852
Total print page counter - rear feed 5250
Total scan counter 961
Ink replacement counter - black 0
Ink replacement counter - cyan 0
Ink replacement counter - magenta 0
Ink replacement counter - yellow 0
Last printer fatal error code 1 0x791E Circuit error or blowout of a fuse. Main board failure.
Last printer fatal error code 2 0x791E Circuit error or blowout of a fuse. Main board failure.
Last printer fatal error code 3 0x791E Circuit error or blowout of a fuse. Main board failure.
Last printer fatal error code 4 0x791E Circuit error or blowout of a fuse. Main board failure.
Last printer fatal error code 5 0x791E Circuit error or blowout of a fuse. Main board failure.
Last scanner fatal error code 1 0x4D Scanner/ADF FB BS+ excess load error. Encoder failure. Tooth skip or improper tension of the timing belt. Gear crack. Cable or FFC disconnection. Motor driver failure. Main board failure.
Last scanner fatal error code 2 0x4D Scanner/ADF FB BS+ excess load error. Encoder failure. Tooth skip or improper tension of the timing belt. Gear crack. Cable or FFC disconnection. Motor driver failure. Main board failure.
Last scanner fatal error code 3 0x4D Scanner/ADF FB BS+ excess load error. Encoder failure. Tooth skip or improper tension of the timing belt. Gear crack. Cable or FFC disconnection. Motor driver failure. Main board failure.
Last scanner fatal error code 4 0x4D Scanner/ADF FB BS+ excess load error. Encoder failure. Tooth skip or improper tension of the timing belt. Gear crack. Cable or FFC disconnection. Motor driver failure. Main board failure.
Last scanner fatal error code 5 0x4D Scanner/ADF FB BS+ excess load error. Encoder failure. Tooth skip or improper tension of the timing belt. Gear crack. Cable or FFC disconnection. Motor driver failure. Main board failure.
Last general fatal error code 1 0x00 Fatal error does not occur.
Last general fatal error code 2 0x00 Fatal error does not occur.
Last general fatal error code 3 0x00 Fatal error does not occur.
Last general fatal error code 4 0x00 Fatal error does not occur.
Last general fatal error code 5 0x00 Fatal error does not occur.
Será que o fusível da placa lógica queimou ou se eu trocar só a cabeça de impressão resolve?? Na verdade eu já tinha comprado uma cabeça de impressão pelo AlieExpress, foi mais a pressa que fez eu tentar o procedimento. Outra pergunta, ao chegar a nova cabeça posso colocar pra testar se funcionaria ou corro o risco de queimar a cabeça de impressão nova?
Paulo Schell
Status Fatal error
2 respostass a esta questão
